Loader JD955/70 loader
   / JD955/70 loader #1
LFH8541
Bradford NH
JD 955
I took my model 70 loader off so I could replace my water pump. came off like a breeze, so simple. I replaced it today and hooked up the hoses as I thought it was,
nope I am wrong. Can anyone tell me the right configuration. I have green, yellow, silver, and unmarked. Help
   / JD955/70 loader #2
Unmarked is black.
Put black and green to lift the loader, and yellow and silver to the bucket curl.
   / JD955/70 loader
Thank!!! I switched green and black and everything works just fine. I'm going to put colored wire ties on so this wont happen again, I've decided I like mowing
without the loader on. Thanks again.
   / JD955/70 loader #4
I have zip ties on each hose equating to whatever number it is.
If I had a quick attach bucket, I might leave the loader on while mowing. Since I don't, I almost always take it off. Much easier to maneuver around trees and such. Or between them when using the 4ft rotary.
   / JD955/70 loader #6
The zip tie trick is nice. Especially once I figured out the ports on the tractor are numbered 1-4 from left to right. I was taking the loader off to mow but now that I've converted to SSQA I find it easier to just drop the bucket. Still not as nice as removing the loader of course.
   / JD955/70 loader #7
I'm not sure which I'll do once I get a SSQA. I think I'll try it both ways and go from there. Since my mower is a 72" MMM, attaching/removing it is harder than mounting the loader.
2005 Ford F-150 Ext. Cab Pickup Truck (A46684)
2005 Ford F-150...
John Deere 5115M (A47307)
John Deere 5115M...
Skidloader Trailer Mover (A47809)
Skidloader Trailer...
2017 Ram 1500 Crew Cab Pickup Truck (A46684)
2017 Ram 1500 Crew...
45in.x15in.x20ft.Feed Bunk (A49339)
45in.x15in.x20ft.Fe...
John Deere Weight Bracket (A46502)
John Deere Weight...
