Jim
   / Jim #1
FauxPas1952
prairieville, la
ford 2000
Were is the location for the fuse box assembly for a Ford 2000 3cyl gas, or does it have one ?? I'm trying to rebuild and I'm having trouble getting this thing to start.. I changed the starting solenoid, changed the starter replaced battery cables and working my way to replacing the key switch.
Thanks,
Jimmy Burns
   / Jim #2
Tip:
Quit replacing thing, and start troubleshooting!
Its cheaper!
You don't give us full details lil trans and fuel, and those make some difference, as twin stick jobs have a range neutral interlock.
Gas ?
Diesel?
Trans type?
Do you own a yes lamp or multimeter?
Can you operate either to check circuit continuity?
Do you have 3' of 12awg to use as a test jumper in case you find a continuity issue?
Depending on the specifics of your machine, a screwdriver or coat hanger is all that is needed to make an otherwise servicable machine start.
Ps, there is a small fuse in the high density plug connecting the dash to tractor harness..
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
