Jimna 354
   / Jimna 354 #1
Rob Larson
Jimna 354
Jimna 354 Tractor will not run on diesel fuel. Will run on starting fluid. Replaced the primer/ fuel pump and have fuel to injection pump. Any ideas out there?
   / Jimna 354 #2
It's not recommended to use starting fluid with a diesel engine. It can cause damage. Was the tractor ever running for your? When you replaced the fuel pump did you set or check the timing? Have you bled the system according to the manufacturer's instructions?
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2023 JOHN DEERE 135G EXCAVATOR (A51242)
2023 JOHN DEERE...
UNUSED FUTURE VIBRATORY ROLLER (A51244)
UNUSED FUTURE...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
