3-Point Hitch Jinma 204 Lift Arms Will Not Stay Up.
   / Jinma 204 Lift Arms Will Not Stay Up. #1
goatboy56
Newbury
jinma 204
My 2002 Jinma 204 lift arms do not stay up when not engaged so it looks like I need to re-build my hydraulic lift cylinder and it looks like I need to take off the shifter gearbox cover to get the cylinder out. Removing the cover does it just unbolt and lift up or do you have to disconnect any shift linkage first?
Thanks,
John
EDIT: it looks like I should go in from the back as I found an old post so any thought would be great.
Thanks Again,
John
   / Jinma 204 Lift Arms Will Not Stay Up. #2
I think it depends on the liftbox model. On mine you come in from the front (the front of the tractor). The cover has to come off of the transmission to get access. My recollection is the bolts that hold the cylinder cover on have some serious torque. Beyond that it's not hard. The piston has a threaded hole that you have to use to pull it out, I think it's 10mm. The piston isn't attached to anything so you just pull it out, replace the seals, and push it back in.
You should be able to tell by the bolts how the lift box comes apart. I think the ones that come apart from the back are more involved to get the piston out.
   / Jinma 204 Lift Arms Will Not Stay Up. #3
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
71064 (A49346)
71064 (A49346)
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
