Jinma 204 PTO Shaft Seal
   / Jinma 204 PTO Shaft Seal #1
crackenzag
branson, missouri
John Deer L130, NorTrac 204C
Hey everyone. I have a moderate fluid leak from the PTO shaft at the rear of my 204. I have ordered a new seal, bearing and cover plate gasket. Has anyone done this repair and have any good advise for me before I start in on this? What and how much fluid will I lose? Is the bearing pressed on to the PTO shaft? Will the PTO shaft just pull out once the cover plate is removed? Is it even necessary to replace the bearing if the shaft doesn't have any play when installed and the bearing is smooth? Just trying to get my ducks in a row. Thanks!!!:D
   / Jinma 204 PTO Shaft Seal #2
I did this repair.
My one piece of advice is to be sure you drain enough fluid out. I thought I had. I took the cover off, and fluid started going everywhere. I quickly threw in the new seal and put the cover back on. Made a mess of my garage.
It's an easy repair. Just remove the cover and put the new seal in. I think it was Tommy at Affordable who told me that sometimes the factory puts two seals on that shaft.
Just did the repair. Pretty easy, no need to remove the bearing but lost pretty much all the transmission fluid.
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2016 PETERBILT 389 SLEEPER (A52472)
2016 PETERBILT 389...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
