Jinma 254 Clutch\Tranny?
   / Jinma 254 Clutch\Tranny? #1
Acres1962
I have an 06 Jinma 254. I had a new clutch installed 3 years ago. The other day while mowing I noticed that it began to hesitate in movement while climbing an incline, or even making a turn. No its not the engine as it throttles fine. It appears as I am climbing the tranny "hesitates" then catches up and moves on. Even making a turn the tractor hesitates for a second and then moves on. It seems like the clutch may be slipping and then catches and grabs? Again I don't believe it is an engine issue as there is no strain on the engine. I changed the trans fluid and replaced with 80]90 oil. Could this be an issue with a clutch adjustment?
   / Jinma 254 Clutch\Tranny? #2
Usually when a clutch goes it slips steadily worse.and much more in higher gears. Maybe you have a sticking brake? If wet brakes, could easily be affected by wrong oil.
Jim
   / Jinma 254 Clutch\Tranny? #3
I have the same or very similar problem with a Farmpro 2430 (by Jinma). Thinking clutch, maybe throwout bearing?
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
STORAGE FEES (A52576)
