Jinma 254 igintion problem
   / Jinma 254 igintion problem #1
john carr
Greenup, IL
Tractor King 254 and iseki
Help, my Jinma 254 tractor blows the fuse when I try to start it. I have replaced both the switch on the clutch and the ignition switch. When I turn the key I sometimes get the starter to run and have started the tractor but then find the fuse is blown when I go to start it the next time. Other times it just blows the fuse. What else can cause the fuse to blow. Bad glow plug?
Thanks in advance.
John Carr
   / Jinma 254 igintion problem #2
i would check the glow plugs next. 1 or more maybe shorted to ground. also check the wiring for the glow plugs.
   / Jinma 254 igintion problem #3
Thanks in advance.
John Carr
On mine, you turn the key clockwise to start with the glow plugs, counter clockwise to start without. Try starting counter-clockwise and see if that helps -- assuming you don't need glow plugs this time of year.
Thanks for the info. I rewired the glow plugs using #12 wire on a separate circuit. Everything seem to work Sat. Now it's Monday morning and I seem to be back to square one except the Glow plugs are not the problem. When I tried to start the tractor it initially fired. But when I tried it a second time it started to blow the fuse again. Also when I turn the switch counter-clockwise nothing happens other than the lights will work. I am next going replace the wire from the switch to the starter with a in-fuse and see if that is the problem! Any ideas
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2011 Liebherr L586 (A52128)
2011 Liebherr L586...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
