jinma 284 pto
   / jinma 284 pto #1
bopboi
katikati new zealand
jinma 284
hi guys, the main leaver on pto not working,not sure if the big spring is the problem,the leaver that operates the speed use that to turn off,but pto keeps going if nothing attached, put new check parts and the part that clicks in the hole it was worn a bit,main leaver not turning off,is it the clutch? read it maybe clutch need adjustment
2004 4WD JEEP WRANGLER (A43004)
2004 4WD JEEP...
INOP/NON-RUNNNING 2016 Freightliner Cascadia 113 Truck, VIN # 3AKJGBDV2GSHC5234 (A44391)
INOP/NON-RUNNNING...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
1998 FORD L800 TRI AXLE DUMP TRUCK (A43004)
1998 FORD L800 TRI...
8x16ft Flat Bed (A44391)
8x16ft Flat Bed...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A44391)
2019 Ford F-550...
