Jinma JM-354 tall tires for row cropping
   / Jinma JM-354 tall tires for row cropping #1
bjr
Veteran Member
Eastern WA
Jinma JM354
Has anyone ever experimented or actually used taller tires on a 4 wheel drive Chinese tractor? I would like some more clearance when I'm cultivating corn? I was thinking like 28" on rears and 20" on front and only use the low gear section of the transmission as I know the road speed would be great. For that matter is there any smaller tractors made 20-50 hp range to row crop with thats got greater clearance? I know you gotta keep a ratio in mind to keep the transmission gears happy. bjr
   / Jinma JM-354 tall tires for row cropping #2
What size is on it now? My 284 has 24's rear bad 16's front. I would think a 354 would have about the size you are looking for from the factory.
Chris
   / Jinma JM-354 tall tires for row cropping #3
I've seen pictures of Jinmas that are made specifically for row cropping with high-clearance drive trains that get them way up off the ground. I don't know if 4WD is an option on those,though. Never seen them advertised in the US, either.
I already own the tractor and yes they are 24's in the rear and 16's in the front. Just wondering anyone else has tried raising one or lifting one? bjr
   / Jinma JM-354 tall tires for row cropping #5
Sorry...:laughing:
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
5' S/A CART (A52706)
2016 Nissan Versa SV Sedan (A53117)
2016 Nissan Versa...
