jinma tractor wont start
/ jinma tractor wont start #1
scavengerr2
littlerock,ca
jinma 284
fist would like to say hi to everyone and hope some one can be some help with my problem.
I have a 2006 Jinma 284 tractor the other day i was discing my back yard and when i finished i drove it around to the front of my house and then the problems started, it was like running out of gas, but started smoking and losing power.
well now it wont start, than the starter stopped,
now this is where it gets weird.
replaced starter turns over and wants to start but wont
drained gas and cleaned all lines, added new fuel pumped system up
again wants to start but wont stay running
pulled all fuel lines and check pressure at pump good
pulled injectors and redid lines and they are all working good
check compression and its good
have no idea where to go from here, injectors work has air bit just wont fire up and run
any help
thanks
Thanks Ron
Funny with Jinma tractors we never stop learning always some thing to work on.
thanks leroy
Thanks hope this forum helps with my tractor. Hope to learn a lot here.
thanks leroy:)
/ jinma tractor wont start #6
Can't help you with yours because we have our own problems with ours. Want to come up and help us with our water problem? Ours is a 2007 284. We replaced radiator, had a popped freeze plug, replaced that and got good compression, but then the breathing tube churned out water and oil mixed. Replaced the head gasket, which looked to be okay, the thermostat cover and gasket, put two small freeze plugs that were out under head and when he added water last night it drained out the oil pan plug. Worried that the engine block is cracked, but not sure how to find out.
Hope you get yours figured out.
/ jinma tractor wont start #7
any help
thanks
Welcome to the forum. Sorry to hear you have problems, i know you turned the fuel shut off valve back on ? You be surprised how many time that has happened.
I hope someone can help you, we have some pretty smart people here.
/ jinma tractor wont start #8
Duke 7595
Seems you know something about these tractors, someone told me it makes a difference if it is a dry liner or wet liner engine, how do you find that out?
/ jinma tractor wont start #9
Duke 7595
I really can't answer because i don't know. However, type your make, model and V.I.N. and Google it, should bring you to some pages where you can research
by your VIN number. Hope this helps.
/ jinma tractor wont start #11
Okay, Humor me at this point. You do mean you drained the "DIESEL" don't you? You may have stumbled on the problem with your description if you really drained "GAS". Otherwise check that you are getting Diesel fuel from the tank to the injection pump. the tank valve on the bottom of the tank has very small orifices and can plug easily. bjr
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
2017 International 4300 Box Truck (A62613)
2017 International...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
