Chipper Jinma Wood Chipper Hydraulic Fluid
   / Jinma Wood Chipper Hydraulic Fluid #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
I am curious as to what type of fluid most Jinma Wood Chipper owners use in the gearbox that controls the hydraulic feed. Thanks
   / Jinma Wood Chipper Hydraulic Fluid #2
Use 75w90 gear oil filled up to the dot.
   / Jinma Wood Chipper Hydraulic Fluid #3
We install 80W90. Nothing wrong with 75w90 in the gear box that drives the mechanical feed drum.
I am not aware that Jinma has a hydraulic feed ?? Can you post a picture ?
Ronald
Ranch Hand Supply
Thanks for replies...
My choice of words was not correct; I meant the gearbox that turns the feed roller. Would it be better to run synthetic or is the straight 80w90 preferred??
   / Jinma Wood Chipper Hydraulic Fluid #5
My opinion........... your call.
Ronald
Ranch Hand Supply
   / Jinma Wood Chipper Hydraulic Fluid #6
I put some Lucas in all gear boxes using 80-90wt. I just had a friend that I told to do that, blow a seal on his mower box. It ran for a while before he found it. It was bone dry of fluid but still running warm to the touch in 90+ weather. I credit the Lucas.
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2012 DOOSAN G25 GENERATOR (A52472)
2012 DOOSAN G25...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A51573)
New/Unused AGT...
