RonMar
Elite Member
I found a good replacement dust boot for the steering cylinder shaft on my 284. With all the brush busting I have done this last summer/fall, I have been a little hard on the original rubber cylinder boot(tore it all to ****
. I came across a Rancho shock boot at a local auto parts store (Rancho # RS1927 $4.99). It is a perfect fit and slips on tight on both the cylinder end and ball joint end. They come in several colors(I chose red to match the tractor) and can be held in place with the stock spring clamps or the Ty-wraps that came with the boot.
I am glad I had to replace the torn boot because one of the pieces of hardware I didn't check for tightness when the tractor was delivered is the lock nut on the end of the shaft where the left hand ball joint is screwed onto the end of the shaft. It was completely backed away from the balljoint and I could rotate the shaft with my hand. This could have ultimatly led to the shaft backing out of the ball joint and a loss of steering. Since it is covered by the boot, I didn't even think to look for a lock nut there... It is easy to check. Stop the tractor with the steering turned all the way to the left and the cylinder shaft/boot fully extended. Compress the spring clamp on the ball joint end of the boot and slide that end of the boot up the shaft towards the cylinder to expose the threaded end of the shaft and the lock nut.
