jonnysteals
Bronze Member
- Joined
- Dec 16, 2009
- Messages
- 68
The tractor was fine the other day. Today I used the front end loader a lot and use the box blade to level some dirt. I did pick up and move some very heavy stumps with the tractor. I generally was not lifting the front end loader up very high in the air. It seemed to work fine but after moving some heavy stumps I could hear a squealing everytime I lift the front end loader.
When I went to put it away I tried to lift the front end loader up all the way and it stopped about 3/4 of the way up. It made this squealing sound and would not lift the rest of the way. I checked the rear transmision fluid level and it was fine. I did not see any leaks or anything. I did a quick insepction of the hydralic lines and I did not appear to be kinked anywhere.
What shoudl I look for. This seems like a hydrolic pump issue not an attachment issue. Is this covered under the tractor warranty because its over one year old so my attachments are no longer warrantied. Any advice would be great. It seems to run fine and drive fine but just cant raise the front end loader all the way.
