john deer 425 oil leak
   / john deer 425 oil leak #1
ny
jd 1070
Hi guys i have a jd 425 that leaking oil from the front main oil seal on the battery side of tractor how do i change it i looed up the part on the jd site its cost 4.00 $ but i do not know how to replace is it a diy or do i need to go to mother deer thank art
   / john deer 425 oil leak #2
There is a gasket inside the main engine cover. If its that. Remove front of tractor, muffler, water pump. Then u can unbolt the front cover. While in there u might want to replace a lot of little things like oil pump, governor gear, water pump, a bunch of other little O-rings, and the cam gear if its plastic. There is also a seal around the front pto shaft. Mine leaks there a tinybit. Not worth all the work to change it.
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
Vermeer BC1800A Wood Chipper (A51573)
Vermeer BC1800A...
