3-Point Hitch John Deere 1050 rear hydraulic down pressure
   / John Deere 1050 rear hydraulic down pressure #1
bblui2
Roseburg, OR
John Deere 1050
My dad is using his JD 1050 utility tractor with a post hole auger. He wants to know if there is a down pressure adjustment on this tractor. There appears to be down pressure when using a cultivator but we have no idea how to adjust it. Thanks.
   / John Deere 1050 rear hydraulic down pressure #2
There is no down pressure on any tractor's 3 point lift (with a few rare exceptions). But there is a down pressure kit that can be fitting to some 3 point post-hole diggers that uses a hydraulic cylinder, which applies downward force on the post hole digger.
   / John Deere 1050 rear hydraulic down pressure #3
put some weight on the 3ph.
   / John Deere 1050 rear hydraulic down pressure #4
Some old foreign tractors have down pressure. The brand new JD 3 & 4 series have an optional kit for 400ish lbs of down pressure or so. But its very uncommon.
You can get down pressure kits for a 3pt PHD for some of the PHDs. Its a single acting cylinder that's plumbed in a little funky compared to more common hydraulics.
Your easiest solution though is to strap or weld several hundred lbs of weight to the end of the PHD. I hang a 5 gallon bucket full of scrap metal & cement with a chain hanging out to attach to the PHD hook.
FIATALLIS MOTOGRADER (A50854)
FIATALLIS...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
MUD MIXING UNIT (A50854)
MUD MIXING UNIT...
