3-Point Hitch John deere 110 tlb issue
   / John deere 110 tlb issue #1
trapper1
John Deere 110 TLB
All of the sudden my 3 point hitch won't stay up when I raise the lever. As soon as I let it go it goes all the way forward and the hitch hits the ground. If I hold it in place by hand I can raise and lower it just fine . I researched the manual and cannot locate any info. It is full of fluid and only has 500 hrs on it. I believe it is a2006 model year.
   / John deere 110 tlb issue #2
So the lever will not stay at the position where you move it to? There is the black rockshaft knob (located roughly between your legs when you are sitting) that controls how fast the 3pt hitch will drop, but the height lever should stay where you put it.
I tried the knob and it does change the rate but still won't stay in place
I tried the knob and it does change the rate but level still won't hold Gannon in place
1986 VIM TACK TANKER TRAILER (A50854)
1986 VIM TACK...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A49461)
2017 Mack GU713...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
