John Deere 2330 inj pump Question
   / John Deere 2330 inj pump Question #1
Tony Tong
John Deere, Dehl,ford
I am dealing with Tractor that will not achieve rpm sluggish off idle too. In troubleshooting I replaced fuel filter no suction side leak air filter ruled out, found if I cracked the inj pump caser drain the rpm rose and engine opoperated normally. this also happened when either loosening the timing adj set nut or the timing window cover. moving the timing adj set screw has no effectc.the return line is not clogged and there is no air in the system. Do I have a inj pump internal seal leaking ?
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
Kubota ZG327 (A50120)
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
