John Deere 410B Hydraulic problem
   / John Deere 410B Hydraulic problem #1
JLazyA
John Deere 410B
I have a John deere 410b hoe with a hydraulic problem. It bareley moves when cold, as it warms up it moves faster. Anything hydraulic, steering, lifting, or hoe. We have changed the screen in the transmission, checked the line to the pump, and rebuilt the pump. And it is still the same. I think it is the priority valve but not sure what to check next.
   / John Deere 410B Hydraulic problem #2
When you say rebuilt the pump are you talking the radial piston pump or, charge pump?
Are you using recommended hydraulic fluid?
Was this a problem before?
Been a lot of activity here on viscosity of fluids. Might be as simple as letting it warm before moving. May want to check pressure and or flow of charge pump when cold vs. warm.
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Diesel Forklift (A51691)
Diesel Forklift...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
