John Deere 4120 Rear PTO stops spinning under load
   / John Deere 4120 Rear PTO stops spinning under load #1
Jercrew
Coweta, ok
John Deere/4102
I have a 2005 John Deere 4120 ehydro 600 hours.
When I use an implement (tiller or brush hog), the implant stops spinning under load. Once I lift the implement from the ground it starts spinning again. I have the correct RPM running, engine never bogs down. I don't use this tractor often, and have had it for 10 years, never used to be like this.
Tranmission fluid looks very clean, going to replace the fluid,filter and clean the inline filter. Not sure this will help. Need ideas of what could be the cause.
   / John Deere 4120 Rear PTO stops spinning under load #2
From what you describe it seems like tour pto clutch pack is slipping, but with only 600 hr it shouldn't be from wear, I am thinking maybe something like debris in an oil passage is preventing pressurized oil that engages and keeps the clutch engaged from getting there.
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
