John Deere 4310 blows fuze F-5 (ignition) when engaging mid mount PTO.
   / John Deere 4310 blows fuze F-5 (ignition) when engaging mid mount PTO. #1
Spectre
Fort Walton Beach
John Deere 4310
It is hit and miss. I started it today and the mid pto started without blowing the fuze, but I noticed the rear PTO was turning at the same time. I turned it off and on a few times then it started blowing the fuse again (three times). Does anyone have a recommendation?
   / John Deere 4310 blows fuze F-5 (ignition) when engaging mid mount PTO. #2
The mid-mount PTO is run off a gear in the rear pto. So it is normal and required for the rear to turn to power the mid PTO. Need a wiring diagram to see what is run off the F5 fuse. I would look under the tractor on the rt side to see if weeds or brush has pulled any wires loose to start.
Thank you...I will look.
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
HARDEE SH-360-CO 5' DITCH BANK CUTTER (A52708)
HARDEE SH-360-CO...
flooring (A55758)
flooring (A55758)
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
