John Deere 4310 mid pro problem
   / John Deere 4310 mid pro problem #1
Joyryd
John Deere 4310
Hi folks,
Looking for some help with my John Deere 4310 e hydro. My machine runs fine, after about 35 minutes of use the pto shuts off. It’s like an electrical issue after warm up. I can hear and see the main pto turn on and off with the button but the mid pto doesn’t. I can let it cool for a bit then the mid will start back up for a bit. I switched the relays in the fuse box with the lights. Just to isolate a bay relay. I bypassed the seat switch and replaced the solenoids all three on the valve bank. I even removed clean and tested then switched the plungers in the valve bank. I also opened the switch panel and tested the on and off pto knobs all tested good. Running out of ideas any help would be appreciated.
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
