madpup
I have a John Deere 4310 with the PowrReverser (so not the Hydrostat) PIN LV4310P135855. I took it out the other day and washed it and now it will not move (so at least it is currently a nice clean lawn ordainment). It starts and bucket works and rear three point works just fine. I checked all the connections for water and all are dry (seat sensor, clutch potentiometer cable, etc.), I checked all the fuses with an OM meter and all are good, I have tried every combination of the range selector and gear shift multiple times and I disconnected the battery for 10 minutes all with no luck. When I am on the seat and I put the tractor into gear and push the PowrReverser lever forward or backwards it just does not move.
What I have found is that when I am on the seat I do not get any error indicator lights however if I get off the seat with the tractor in gear normally that would cut the engine, however what it is doing now when I get off the seat with the tractor in gear and the PowrReverser lever in forward or reverse is the engine does not cut out and instead I get an error code of one long flash, one short flash and then 6 short flashes. I some posts on-line talking about the Clutch Potentiometer (it has a partnumber printed on it of RE53380A) or the clutch switch (more looks like a button) could be bad but I don't know how to test that or confirm from the error code when I get off the switch if that is the problem or not. I also find the timing strange since the Tractor has served me well for the past 9 years and this happened right when I went to move it after giving it a good bath.
I don't know if I can use my OHM meter to test the Clutch Potentiometer or if I can pull the cable from the Cluch Switch (button) and try jumping that or where to go from here. Any help would be appreciated.
