John Deere 4400 steering cylinder failure $$$$$$$$
   / John Deere 4400 steering cylinder failure $$$$$$$$ #1
Cactus
My steering quit working on the JD 4400,so I called John Deere and it was about $700 to replace. JD does not offer a rebuild kit,so I dissected the cylinder and the o ring in the center of the cylinder is has worn on one side from where I had slightly bent the shaft.The inside of the cylinder was scored as well.I thought I would be able to repair the cylinder myself but up on seeing the wear on the inside of the cylinder I realized a trip to the loacal machinist would be my next option. I go to the machinist and after about 45 minutes of discussion they inform me they can make a whole new steering cylinder,one that can be opened up and serviced for about $400.They say it will be next week before it is ready and I say noooo problem I can wait. I also have had some issues with the tie rods wearing out and if everything looks good after the steering cylinder rebuild I am going to consult with the machinist about making a different and improved tie rod end as well.On my JD 4400 the old style axle(turf destroyer) which I have the tie rod ends coming off of the cylinder is not much bigger than a number 2 pencil and these things wear like crazy and JD wants about $190 apiece for these.
If this project works out good hopefully I can post some pictures.
DANA corp has designed this front end right down to the pinion gears in the front end.
Cactus
New Land Honor Screening Deck (A48289)
New Land Honor...
2013 John Deere 4520 4WD Front Loader Utility Tractor (A46683)
2013 John Deere...
Power Screen HX5000 (A45336)
Power Screen...
2017 Ditch Witch Trencher (A46683)
2017 Ditch Witch...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A48561)
2021 John Deere...
1999 Chevrolet Suburban SUV (A45336)
1999 Chevrolet...
