john deere 4410 won't move forwards or backwards
   / john deere 4410 won't move forwards or backwards #1
desdan2
i have a john deere 4410 e hydro compact that when i shut it down and restarted next day it will not move forwards or backwards, checked all fluids, no blown fuses, all hyds work fine, seat switch checks okay, pedals full up not stuck, all connections okay at foot switchs, pto fine , loader fine mower pto fine, no noises, i suspect electrical power to foot switchs but do not no how to check!!!! any help would be appreciated
   / john deere 4410 won't move forwards or backwards #3
I had same happen, it was a break in the wiring harness. I did not have a way to trace it, took to dealer and they replaced the section of the harness.
Was not an expensive repair other than the down time. Good luck
   / john deere 4410 won't move forwards or backwards #4
That little light on the right console should blink a code. That will give you a place to start.
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2014 Mack CXU613 Semi (A50514)
2014 Mack CXU613...
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
UNUSED FUTURE HYD HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE HYD...
