john deere 445 fuel issue
   / john deere 445 fuel issue #1
zp18
macungie,pa
1946 farmall H , John Deere 4200 , John Deere 445
hello. i had posted a thread on hear awhile ago about my john deere 445 running rough. i have replaced the spark plugs, map sensor, air temp sensor, fuel filter, coils. it could still drive before... somewhat. it runs then looses rpms and bogs down and almost completely shuts off. just yesterday while 'trying' to plow with it, as i went to start it up, i heard the fuel pump priming up, and it sounded as if it wasnt priming correctly. instead of having the same tone , it had a few tones. so i am wondering if the fuel pump is shot.. causing the tractor to run rough and bog down. as of now, i cant drive it more than 5 feet without it bogging down and almost completely dying on me. very useless when it comes to plowing snow. let me know what yous think. Thanks!
   / john deere 445 fuel issue #2
Does it smoke at all during that time? If it is smoking black then it has plenty of fuel. You could have an injector problem. The injector sits in the throttle body. A 445 doesn't have a carb on it. Sometimes those injector will start dumping fuel into the engine. It dumps so much it will fill the crankcase with gas so check your oil and make sure you aren't gaining. If it isn't smoking really black then it could just be the fuel pump not picking up fuel or just going bad. I assume you have been changing your fuel filter once a year.
it doesnt blow black at all. ill check the oil tomorrow. i was thinking it was the fuel pump too but before i go an spend even more money on it i figured id give this a try again. and yes i just changed the fuel filter in like july or early august
   / john deere 445 fuel issue #4
You should be able to take the fuel filter out and stick the hose from the fuel pump in the tank to a container and turn the key on and see if it is pumping fuel. Unless the pump starts messing up once it builds a couple psi.
   / john deere 445 fuel issue #5
good idea to find a way to get that supply line off going to the carb and see how the fuel
stream looks. another possibility is that there is an obstruction in the tank interfering
with fuel flow into the pump. you would be amazed at what can be found in a fuel tank,
from leaves, pine needles, parts of gas cans, fuel caps, plastic, stones....
if your pump has been run dry for a little while (maybe someone runs out of gas but keeps
trying to start the tractor) it can take out the pump also. learned that one the hard way,
as SO was out of gas and kept starting the tractor, driving it 5', it would quit, she'd restart
it and try to drive again, its quits, until the pump gave up!
   / john deere 445 fuel issue #6
Ya that's true about debris. I used to work at a deer dealer a few years back and they found paper towels in the tanks before. The big opening is nice for filling but a pain to keep stuff out of when it's breezy or anything.
thanks guys! ill have to rip the body off this weekend and try that out. at this point it has to be something with the fuel system. i just havent gotten it completely figured out yet. and the 445 doesnt have a carb. it has a throttle body and injector. just saying. i havent run it completely out of gas at all, i always will it up when ever it hits about 1/4 tank. and yea.. i get to like 5 6 foot and it wants to completely die , i have to let off the gas pedal for it to build rpms back up.
   / john deere 445 fuel issue #8
technically it may not be a "carb" but, it's a similar component with a single injection
into the throttle body instead of multi port injection like a car has. either way you
can pull a line and see how fuel flow is, cycling the key on after the pump quits to see
how long it pumps gas and how the stream is.
any chance there is something other than gasoline? my boys dumped my chain saw
mix into my old 445, and with the oil mix it wouldn't run. thought my whole engine was
crapped out, turned out to be just the oil mix. drain and clean fuel and it was good as new.
i know what you mean. i was just sayin. ill take the line off and check that tomorrow night or saturday mornin. i dont think theres anythin else in it.....unless somebody dumped something in there.... its been runnin like this since summer... drained the tank in summer and it still ran like crap. and its just gotten to the point within the last like 2 weeks where its completely useless and doesnt even drive.
   / john deere 445 fuel issue #10
I think you have a crack in the rubber hose on the fuel pump assembly. Pull it out of the tank and look close, replace it while it's out. Seen this many times.
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2021 International HV507 4-Door 4x4 12ft Dump Truck (A51692)
2021 International...
