pclausen
Veteran Member
Hi guys,
I just picked up a used 3 bottom plow this weekend. I have a couple of questions about the overall condition, what size it is, and if it is a shear-bolt or trip type.
So here are some pics of the unit:
Serial # (109160) I wonder if I can use this to determine how old it is? I'm pretty sure is it a 1970+ model since there are 3 bolts holding each board, not 4.
Am I correct in assuming this is a 16" plow given this measurement?
And is this a trip type plow? I see grease fittings so I assume it is.
It looks like the whole thing will come apart into manageable pieces that I then plan to sand blast, prime and repaint. Assuming this is a trip type plow, I'm pretty sure it won't trip right now due to everything being rusted together. Should I replace the trip pivot studs? How do I test the trip feature and how do I reset after a trip?
There is no rear furrow wheel, nor disk coulters. It doesn't look like this particular plow ever had those. I will be plowing about 4 acres that was a stand of dense pines just 6 months ago. There will be lots of roots and stumps. The loggers knocked over some of the stumps for me and I have removed those with my grapple. There are a number of smaller stumps that are cut off flush with the ground. I was going to stump grind them down about 10 inches and then just run over them with the plow. Maybe I should take the effort to dig them all out instead?
I do have a 8' disc harrow that I plan to run once I'm done plowing, so I'm thinking the lack of disk coulters is less of an issue.
The guy I brought the plow from had a JD 4410, and this was way big for his CUT. I have a 4700, which I don't think will pull it either, but I'm in the process of trading it in on a MY2012 5085M, which I'd like to think would be enough tractor to pull this plow.
Paid $450 for it, which I think is a good deal based on various other ones I looked at. I plan to convert these 4 cleared acres to a large vegetable garden and sell produce at local farmer's markets.
Sorry for all the questions!
