John Deere 5320 does not try to start.
   / John Deere 5320 does not try to start. #1
Kmicah40
Bronze Member
Butler, KY
John Deere 5320, ‘56 Ford 601 (been in family since new), 2010 Kubota 900RTV, Cub Cadet 2284, Cub Cadet 2064
I have a 2005 JD 5320 with power reverser and after 3 hours of bush hog work I put tractor in park and shut off engine to unhook the bus hog mower. When I got back on the tractor to move it to the barn it would not start. No sounds at all when trying to start it. Everything electronically seams to be working just fine. Is there a safety switch that might be causing my problem? I’ve had issues in the past where it would not start but I could put tractor in neutral and then it would start. Almost seems like there might be a switch that is not making contact and that won’t let me start the tractor. Any advice on where to look would sure be helpful.
Thanks.
Larry H.
   / John Deere 5320 does not try to start. #2
Sounds like a safety somewhere - PTO, seat, neutral, - you know the list!
   / John Deere 5320 does not try to start. #3
Actually, it does indicate something is "not making contact". Just where to look would depend more on what other details are in play other than it "won't start".
When this happens, do any of the headlights work? When you turn the key on do any gauges and warning lights come on? Does ANYTHING electrical seem to work other than the starter?
You may have a safety switch issue, or a simple connection issue somewhere else. Battery, cables and cable connections are just as prone to problems as any switches.
   / John Deere 5320 does not try to start. #4
I have a 2008 4520 P reverser.
and had the same problem got off the tractor to open the gate engine quit. after looking for a problem found a loose wire to the sensor to the clutch side. of housing .
then over the years of using figured out every sensivity part of this tractor is hung onto at the bottom of the tractor.
weird electrical problems always when away from the shop . look closely at your electrical schematic. then locate the sensors installed
The error code on the dash usually will tell you the left turn blinker light filament is open. never tells you that the sensor wire is disconnected.
I ended up using tie wrap to each connector connection to keep the connection tight.
The red wire to all electrical points going into a crimp connector below the deck plate and 4 red wires connected should be crimped again.
ken
Thanks for all the reply’s and suggestions as where to look. Well this morning I started by checking the safety switch under the tractor. As soon as I crawled under the tractor I saw my problem. Evidently while I was bush hogging I ran over a wood branch about 2” in diameter and somehow the end of the branch wound up lodged between the frame and steel rod where the safety switch is located. The safety switch was hit and uncoupled which was the reason for not being able to start the tractor.
   / John Deere 5320 does not try to start. #6
Good it was so easily found.
The error codes should plainly be printed on the dash or in some area to be seen getting a code flashing have to go to the shop look up in a book if needs to be fixed or just some engineer that never drove off blacktop or polished cement. the idea of warning. ken
   / John Deere 5320 does not try to start. #7
Know this is an older post of tractor not running.
Past week my John Deer 4520 power reverser would not start. The day before had used bush hog for approximately 2 hours with no problems. Looking for the problem, I saw the dash instruments clouded and smoked looking
also needed to replace the front-end loader after a bushing on top of the mast had broken allowing the arms to twist and mess up the hydraulic piping breaking the cross member if had been moving would of run over the loader.
Listing the problems I was having went to local dealer 45 miles away. His suggestion was a new 400X loader. about 6K and availability ?
then the Dash problem wiring harness LVA15109 1091 bucks
instrument cluster. PD4282502 or LVA12705 1254 bucks
Labor, a guess, is around 1000/1500 bucks. anyway, easy estimate of 20 thousand to repair the tractor. told him would think about the cost.
Driving back to the place, I passed a Massey Ferguson display of tractors stopped in and looked at a 1800 series MF is 35Hp a lighter weight tractor but don't need a bigger one
just used to keep the fence row cleaned.
also can use most of the farm tools I have
Talked to my wife and purchased an 1835 had delivered the next day.
so far working well needing to remove the wheel weights and put them on the MF.
The John Deer Have not decided but think will sell to a salvage yard for parts.
At 89 the neighbors think I'm nuts but explained it didn't cost them a dime.
Do have a question if the situation was yours what would you have done. ?
ken
   / John Deere 5320 does not try to start. #8
I would have likely done the same as you did. That damaged tractor would have been expensive to repair, and a long time in the shop. Sometimes it's just best to bite the bullet and move on.
   / John Deere 5320 does not try to start. #9
No question at 89 to get what works for you at the moment. Not my choice of color, but don't fault you for a split second for what you did. Enjoy the time on red. 😁😁
3108 (A49339)
3108 (A49339)
Rhino TW96 3pt PTO Brush Hog (A43476)
Rhino TW96 3pt PTO...
Lockwood 2 Row High Capacity Harvester (A47369)
Lockwood 2 Row...
Gas Powered Water Pump (A49339)
Gas Powered Water...
2014 Kia Optima Hybrid Sedan (A46684)
2014 Kia Optima...
76in. Skid Steer Skeleton Bucket Low Side (A49339)
76in. Skid Steer...
