JOHN DEERE 6920 AIRCON SUCTION HOSE FREEZING
   / JOHN DEERE 6920 AIRCON SUCTION HOSE FREEZING #1
newtonbury
HALF WAY BETWEEN BEDFORD & CAMBRIDGE UK
CASE MX285 Massey 135,JD 6800,JCB 3CX,VALMET 6050,SAME 160 TITAN ,SEVERAL OLD NUFFIELDS ,IH TD9 1949,IH FARMALL 1947 WITH P3 CONVERSION , DEUTZ DX4 70
Hi All !I've got a problem with friends JD 6920 aircon .It has a new compressor ,dryer & expansion valve, it's been thoroughly flushed using a solvent flushing fluid,has no obvious blockages - all screens are clear but within a minute or less after starting it will freeze the suction hose.
Initial running pressures are fine at 2bar low - 10bar high but once it freezes it drops to <1bar low 6bar high and thaws intermittently then runs for short time until it freezes again.Should I be looking to change the thermostat control or the low/high pressure sensor/switch on the high pressure line before the evaporator ? Any suggestions would welcome !
   / JOHN DEERE 6920 AIRCON SUCTION HOSE FREEZING #2
Are you moving enough air across the evaporator? No rat nest or debris/trash/foam filter blocking airflow? Both pressures (high/low) drop so it's not an internal restriction. If it were an expansion valve sticking or metering device blockage, the low side pressure would drop and high side would rise (climb). Frost is always visible after a pressure drop too great or restriction. I don't do automotive refrigeration but I've done residential my whole life and have a non-restricted state license. There are similarities....enough to get me in trouble..haha!
   / JOHN DEERE 6920 AIRCON SUCTION HOSE FREEZING #3
I agree with PBettis to check the evaporator coil, all it takes is a poor fit on the air filtration system in a dusty field to block it up. If the coil and gas inside doesn't have enough air flow across it the return line will freeze quickly. In most residential systems I expect to see the return side of the evaporator to run about 40 to 45 degrees.
ALLISON TRANSMISSION (A53843)
ALLISON...
2019 Nissan Sentra (A51694)
2019 Nissan Sentra...
Travel Trailer (A51694)
Travel Trailer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
