John Deere 720
   / John Deere 720 #1
Johndeere720
WI
John deere
I have John Deere 720 that blows smoke out of the oil cap on the side of the tractor and there seems to be alot of pressure there. I tried a to put a breather on it but it didn't seem to help. Is there any ideas that I could use and try to fix it.
   / John Deere 720 #2
Well all you can do is a breather cap which you did.You are having blow by must likely one of your valves isn't seating right.Most likely u have carbon build up.you could try a oil additive to the oil that helps clean the engine.other then that you have to do a compression test to see which cylinder has less.
John Deere 535 Discbine (A47809)
John Deere 535...
Towable Toro Topdresser 2500 (A46683)
Towable Toro...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A46884)
Kubota 24in Quick...
2023 Komatsu WA320-8 Articulated Wheel Loader (A45336)
2023 Komatsu...
Rears 500 Gal Orchard Sprayer (A47307)
Rears 500 Gal...
Rears 1000 Gal Orchard Sprayer (A47307)
Rears 1000 Gal...
