John Deere 755 blowby
   / John Deere 755 blowby #1
Marty6645
I have a John Deere 755 with 2100 hrs on a 3 cylinder yanmar. Tractor has quite a bit of blowby through the vent tube. I was wondering if this was a sign the motor needed rebuilt. Tractor is running with plenty of power. Just alot of smoke.
   / John Deere 755 blowby #2
Marty6645 said:
Tractor has quite a bit of blowby through the vent tube. Just alot of smoke.
I would be preparing to rebuild it...
If you've got blowby , excessive oil consumption and pressure loss, excessive smoke and maybe a loss of compression, its time to rebuild before it gets really expensive...Its only going to get worse and it could destroy itself in the process...
Rob
   / John Deere 755 blowby #3
I just noted your glowplug thread...
hard starting or failure to start (especially in cold weather) can be caused by faults other than worn engine (blocked filters ,glowplug failure etc) , but in your case I would expect that the two go together..
I'd also try to return it to the guy you bought it off...
Rob
   / John Deere 755 blowby #4
How much did you give for unit? Did you buy it knowing/thinking that a rebuild was in your near future?
   / John Deere 755 blowby #5
Diesels need compression to run. You might have a problem here. The blow by would tell you the rings are leaking compression which in turn would give hard starting.
   / John Deere 755 blowby #6
How many hours?
New or used?
Have you done the oil changes yourself?
Diesel rated oil?
Bob
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2002 Scag STT61A-27KA Turf Tiger 61in Zero Turn Mower (A50322)
2002 Scag...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
