John Deere 755 compact tractor
   / John Deere 755 compact tractor #1
BLC755
blc4570@yahoo.com
Fuel shutoff solenoid wont stay in! To keep tractor running ?
I used 755 the other day! Ran fine like usual!! 1986 I've had it 20 years ! Went to use it next day! Wouldnt start i noticed fuel shutoff wasnt retracting. So i knew to push it in started right up! But a little imconvenient to take side panel off every time to start it! So i took off solenoid noticed black wire was broke off going into solenoid. So figured this was problem! Bought a new solenoid installed it!!! Well now it starts but doing exactly the opposite ! Starts hold in coil works but wont stay running ? Hold in coil only uses 1amp fuse is good ! Any ideas on what problem could be? Thanks
Well 138 views but no answers ! I got it going i installed new solenoid and adijusted linkage same as old one ! I unhooked linkage cranked on it it sucked right in !!! Old solenoid must have had wear on it ! I adjusted new one starts right up! I guess probably wasnt letting it go in far enough is my guess! I guess you'd call it determination! American ingenuity or just tinkering with it till i figured out to get it running !!!Anyways thanks for all the views!!!!
   / John Deere 755 compact tractor #4
We all knew you could figure it out.. :D
Ha ha ha what is it serendipity!!!! Discovered by accident!!!!!
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2015 LINDE H80D FORKLIFT (A50854)
2015 LINDE H80D...
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
