John Deere 770 information
/ John Deere 770 information #1
Dmpalinkas
John Deere 770
Hello- I just bought a JD 770 to maintain a gravel driveway and plow snow, etc...and unfortunately cannot find much information on it. I was told that it is an '89, but looked up the model #/serial on the JD website to confirm and cannot find a match. Also- I absolutely cannot find any good, reliable information on the engine. The person I bought it from said that it was the upgraded engine that was 30 hp, but again- I can't find (reliable,consistent) information on this engine model # on any Yanmar and/or JD website.
Does anyone know any resources that I haven't found yet?
Serial #on the engine... *CH3045D001835* Model 3TN82 - RJK
thanks for any help!
/ John Deere 770 information #2
Engine may be a Yanmar. Maybe you could find some info through Yanmar. Or give a post on the JD forum, there's sure to be a 770 owner in there someplace.
I used to have a 2004 790, but that isn't helping you out a whole lot. :welcome:
/ John Deere 770 information #3
Go to JD parts . com . Type in 770 model and doalphabetical., search . There will be serial # breaks in the listings. That tractor was made for 2 years by Yanmar . Is the tractor new to you The Yanmar engine is the best , i t brought Deere into small tractors .
Thanks, I'll try the JD forum.
/ John Deere 770 information #5
The engine has a Yanmar PN...if fact, the whole tractor is a Yanmar build. Per Tractor Data.com, the 770 uses a 3TN82-RJX engine rated at 24 HP. The 770 has 20 PTO HP.
The serial numbers are as follows:
770 Serial Numbers: (Location: Below PTO)
1989: 1001
1990: 4111
1991: 100001
1992: 115001
1993: 120001
1994: 130001
1995: 140001
1996: 150001
1997: 160001
1998: 170001
As far as the "30 HP" upgrade, I think the seller was BSing you.
More info: TractorData.com John Deere 770 tractor information
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
SKLP SK-SYLJ100 Hand-Use Hydraulic Track Pin Press Machine (A60463)
SKLP SK-SYLJ100...
Vertical Steel Well Tank (A61570)
Vertical Steel...
ATTENTION PLEASE READ (A60463)
ATTENTION PLEASE...
