John Deere 790 Electrical Problem
   / John Deere 790 Electrical Problem #1
BigMomma
NJ
JD 790
Looking for ideas/help. I have a JD 790 - which is a great machine - ~550 hours - very well maintained and has always run great. It worked perfectly on Saturday - went to start it yesterday, and it is totally dead. Not even lights - nothing happens when you turn the key (guages,etc). I am trying to diagnose and fix the problem.
The battery was old, but still holding charge - nontheless, I replaced it. Cleaned the ground, checked the fuses, all safety switches are in their proper starting position. Chatted with a local used equip dealer and he didn't have any other ideas.
I'm perplexed - any ideas?
Thanks for the help.
   / John Deere 790 Electrical Problem #2
did you check the MAIN fuse located near the starter...its like a 60 amp fuse or so.
   / John Deere 790 Electrical Problem #3
Some tractors also have a "fuse wire". That one is harder to find and can look o.k. on the outside casing, while the insinde wire is burnt off, thus acting as a fuse.
Thanks for your help and quick replies. The Main Fuse was fine, but glad to know about that one.
I found the problem to be the Ground CABLE. It looked fine, but surprisingly was corroded inside the casing - never seen that. I replaced the cable and am up and running.
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
