John Deere B clutch problems
   / John Deere B clutch problems #1
Krump
Whitemouth, Manitoba Canada
Kubota 3000 DT
I pulled apart my clutch today and have a It manual on this tractor, but it is not very explicit in that I could not get the clutch drum off the splined shaft. The previous owner put in a extra clutch plate?? and its got me confused as I know how many plates should be in there but which side of the clutch plates go against what?? I purchased 2 new round disc plates that has fibre on both sides. Just can not get the clutch drum out that is on the spline and I am concerned about damaging it. I took off the big bolt in the middle of the drum and put the 1/2 bolts into the holes to pressure it out but no go. Any advise folks?? Anyone got a really good diagram of this too??:confused2:
   / John Deere B clutch problems #2
:welcome: to TBN
Above or below the s/n B201000 ??
You can see the clutch diagram for above and below the s/n break point by going to jdparts.com.
Not sure it will help you break it loose, but may be what you need for confidence.
2019 John Deere 3025E (A50120)
2019 John Deere...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
