Mowing John Deere B with flail mower?
   / John Deere B with flail mower? #1
deereman10
Bronze Member
Elroy, WI
John Deere 2440
Would it be possible to use a flail mower or whirlibird mower whatever with a john deere B?
   / John Deere B with flail mower? #2
If it has a pto shaft on the tractor centerline and a 3-point hitch, sure. You may need to add a few hundred pounds of weight to the front end to balance the weight of the mower.
   / John Deere B with flail mower? #3
You're pretty lean on hp with a B. Anything can be done, it's the results you may not be happy with.
   / John Deere B with flail mower? #4
Which "B"? Early models would probably struggle with a 4' mower. Late models should handle a 5' mower.
Does it have a PTO? (Required to power the mower).
Does it have a 3-point hitch? If not, you could still use a pull-type rotary cutter.
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
1041 (A50459)
1041 (A50459)
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
