John Deere Lt319 mower
/ John Deere Lt319 mower #1
Daren betzold
Farmington
John Deere lt 319
Tractor runs great until I engage mower, will mow ok I short grass but will lose rpm's. Replaced both fuel and air filters,fresh gas and deck moves freely. Tia.
/ John Deere Lt319 mower #2
Take out the battery and have a load test done on it. It takes a lot of amps to engage the pto clutch. if the battery is marginal it can loose too much to keep the tractor running.
/ John Deere Lt319 mower #3
Not familiar with the 319- is it two cylinder? If so try removing one spark plug boot while the engine is running. If it dies, that cylinder was doing all the work and the other has an issue. Repeat with the other one. You can learn quite a bit about how they're running just by listening. Then you gotta figure out if it is spark, compression, fuel, etc.
Mower can drive around great on one cylinder sometimes but it is really obvious you've got no power one engaging the mower. G'luck.
DYNAPAC CC524HF DOUBLE DRUM ROLLER (A64279)
DYNAPAC CC524HF...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
