john deere model m
   / john deere model m #1
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
I have a 1952 john deere model m that has been in my family since 1955 it is in fantastic shape however it sat for a couple of years outside with no tin can on the stack now the engine is stuck. How hard of a job is it to rebuild this engine?
Lea
   / john deere model m #2
Try soaking the cylinders with some diesel fuel, maybe you will get lucky & it will break loose??
   / john deere model m #3
Just for a little comparison.. I rebuilt a 40 recently (the model after the M) with .090 over pistons, new bearings, new valves, guides, etc, for right around $1400... Your labor price might be a little different where you live, but that should give you a ballpark if it needs a total rebuild...
   / john deere model m #4
Yes diesel fuel or even ATF transmision fluid down the spark plug holes and let it set. then a few days - weeks later drag it with another vehicle and see if you can break it free by letting out the clutch in 3rd or 4th gear.
   / john deere model m #5
There isn't much on the two cylinders. A rebuild should be fairly straight forward with the right knowledge and tools.
If you have the head off you can fill each cylinder with a 50/50 diesel / brake fluid mix and let it sit. You can also get a block of wood that fits into the cylinder to tap on the pistons ( be sure it is a good snug fit with the cylinder walls to prevent the block of wood being punched through the top of the piston- equal pressure a cross piston head) each day and remember to top up the diesel / brake fluid mix as needed.
Just out of curiosity are you going to restore it?
Yes Mike I am going to restore it is in too good of shape not to do something with.
Lea
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
7033 (A51691)
7033 (A51691)
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2015 Crane Carrier Co. Low Entry T/A New Way Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
