John Deere PK-03 Offset - setting tongue pressure?
   / John Deere PK-03 Offset - setting tongue pressure? #1
Cw733
New Holland Powerstar 100
I have an old PK-03 that has been almost completely rebuilt, but I'm not sure what is going on with the lift spring on the tongue. I broke the original spring and have replaced it ($600 bucks yay!). At some point, someone has added a tab with a new hole to the front of the piece attached to the axle that pushes the parallel bar/spring as the wheels lower and raise. This was done because the original holes just won't work, they end up being too far rearward for the tongue to work correctly. I'm beginning to think that someone has replaced or shortened the parallel bar and added this tab to compensate.
Hoping you guys can answer a couple questions:
1) Can anyone with a PK-03 give me a measurement on the parallel bar between the hole that attached to the spring and any of the 3 holes that attach to the axle? Trying to verify mine has not been shortened. The parallel bar is the square tubing on top of the discs running between the flat spring on the tongue and the axle.
2) How do you guys set the parallel bar/spring on an offset like this? If I set the parallel bar so that the disc is level when raised, then the tongue has a lot of down pressure (pressure on front gang) when the disc is completely lowered to the ground. Is that right?
2011 John Deere HPX Gator 4x4 Utility Cart (A44572)
2011 John Deere...
2025 AllMetal K0720 UNUSED 20 ft. Bi-Parting Metal (A47484)
2025 AllMetal...
2025 Wolverine EX-66-78L Pallet Fork Extensions (A47484)
2025 Wolverine...
1968 John Deere 4020 with 7ft Mower (A46877)
1968 John Deere...
2025 Wolverine TR-26-02C Class 2 Quick Hitch (A47484)
2025 Wolverine...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A44572)
2017...
