John Deere Temp. Gauge
   / John Deere Temp. Gauge #1
StrutnBPS
John Deer 5103
I have a 5103 that the instrument panel has shorted out due to moisture. After researching this seems to be a common problem with this model. Since I plan on keeping the tractor and not reselling it I really only care for the temp. gauge to work. I've looked at a few universal temp. gauge kits. Would these work? Any advice from someone that has dealt with this issue before?
John Deere Temperature Gauge
   / John Deere Temp. Gauge #2
A universal temperature gauge would probably work. You can get electric or mechanical. With mechanical the sensor is permanently connected to the gauge and you have to figure out how to route the line without disconnecting anything. If you go for the electrical kind the sensor needs to match the gauge. Either way the sensor needs the proper size and thread pitch to screw into your block to replace the original. (I did it with my Mitsubishi.)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
