john deere tractor
/ john deere tractor #2
Rod seal or piston seal? If it's the rod seal, rebove the rod end from the pin and unscrew the rod cap off the cylinder and replace the seal and put it back together. If it''the piston then you'll have to pull the rod by remove the rod camp and pull the rod out and replace the piston seals AND the rod seal. Extend the rod almost all the way out before you remove the rod cap to minimize the ammount of fluid you'll spill.
/ john deere tractor #3
If you are leaking oil around the wiper seal you will need to replace the o rings inside the cylinder. the wiper seal just keeps the dirt out. I just rebuilt 4 cylinders on my jd backhoe because of leaks. It aint fun, but hyd oil aint cheap either. good luck
JOHN DEERE 4640 TRACTOR (A62130)
JOHN DEERE 4640...
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
(INOP) CLUB CAR ELECTRIC GOLFCART (A62131)
(INOP) CLUB CAR...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED WOLVERINE TDB-11-72W 72" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2016 NISSAN JUKE (A62130)
2016 NISSAN JUKE...
