john deere x 500
   / john deere x 500 #1
pittfan924
john deere x500
Wondering about the john deere x 500 anybody use it on a hilly slope salesman says it can do the job, I am a little nervous about it. I also want to get the bagger and snow thrower.
   / john deere x 500 #2
The salesman speaks the truth. Recommend the X500 highly. It's an awesome mower that climbs hills like a Billy Goat! Be sure to get the knobby rear tires. I think they are referred to as type CDAP? No opinion on the bagger or snow thrower since I don't have those.
   / john deere x 500 #3
HDAP (Heavy-Duty All-Purpose). :)
get wheel weights too. You wont be sorry. x-500 is the entry level GARDEN tractor series and has differential lock, which you will want. Dont be tempted by anything less.
   / john deere x 500 #4
The 47" snowblower for the x500 series is awesome! I am so glad I got mine when I did, just in time for those big snows we had back in 2010/11. We got hit pretty good for this part of the country with 70+ inches of snow that winter. In comparison barely a flurry this past winter, i never even started it up. Wife says I mounted/dismounted the snowblower for nothing. I said I'd rather do that three times than shovel our drive even once.
The Powerflow bagger system is good too. I think they could have done a little better on the bag design and how they sit in the frame. A lot of grass accumulates at the top that you have to clear away by hand or the bag will not seat in the frame properly after you empty it. I never had that problem on my previous JD mower.
There is a difference in the weight of the machine over smaller series lawn mowers like the LA1xx series. Depending on your lawn you may see ruts develop if you run in the same mowing pattern too often. I alternate between four patterns to avoid this, but I've always done it with whatever size mower I had.
   / john deere x 500
Thanks so much for the help, I was back to the dealer and they want what I thought was a lot of money for the hdap tires instead of just switching them for free, it narrows the cost of the 500 and the 530 anybody think I should go for the 530, I know it has power steering and hydro lift, other than that is it the same tractor?
   / john deere x 500 #6
I bought the X540. For the hydraulics, and more importantly, the water cooled engine. The steering is great, and the engine is even better! It is very quiet.
   / john deere x 500 #7
The JD website has the specs for both models. On the X500 the steering is very easy even though the tractor with 54" deck weighs around 800 lbs. The deck lift on the X500 uses a foot pedal on the left side. It's also easy to use. There's something to be said for simplicity. If a part doesn't exist then it will never break. Hard to believe the dealer would charge for the HDAP tires. Maybe time to talk to a different dealer?
JohnDeere Lawn Tractors Select Series X500 JohnDeere.com
   / john deere x 500 #8
I had a x540. Hydraulics are awesome and worth the added money. Liquid cooled is great too.
The diff lock cant be beat. I mowed a 20*+ slope with no issues.
Very good mower. Better than my BX for sure. Fast, quiet and smooth.
   / john deere x 500 #9
Had an x500 loaner for a few weeks, biggest dissappointment was how they guzzle the gas! They are thirsty, expecially when worked. Other than that, nice mower.
   / john deere x 500 #10
The hydraulic steering is interesting in that there is no mechanical connection between the steering wheel, and the steering linkage. That is why 'tilt wheel' is only on the models with the hydraulic steering.
The liquid cooled engine is slightly less displacement, and is the same HP as it's air cooled cousin. It seems logical that the L/C engine may get better fuel mileage. No doubt that the L/C engine will last longer..
The only reported issue relating to reliability with these X5 series tractors seems to be the PTO clutches. They are the same on all the X5's, so that won't factor in your decision.
2000 Polaris Sportsman 50 (A50515)
2000 Polaris...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
Mayrath Swing Away Auger 10-62 (A50514)
Mayrath Swing Away...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
