john deere X 700 now soloniod power
   / john deere X 700 now soloniod power #1
chazdo2
Bronze Member
auburn new york
walk behing power drive 21
My X 700 wont start. Jumped solenoid turns over easily but no spark. Purple wire on solenoid never gets 12 volts. Tested seat hydro pedal switch and parking switch all good. Blade or pto switch is disengaged. Please help!!!
   / john deere X 700 now soloniod power #2
X700 Gas (Carb) Correct ?
1.) Battery and its connections
2.) Check fuses and connections (Says there is a fuse box)
3.) Does dash cycle correctly, Do you hear fuel solenoid on carb, or the fuel pump (In Tank)when turning key?
Starter looks like at least 3 wires are hooked to it besides the heavy battery cable, and ground via bolts/casing.
4.) Ignition interlock module? I can't find it on either the old or new JDParts site. I wondering if it is part of Instrument Cluster?
Looks like there is a diagnostic port off the instrument cluster
   / john deere X 700 now soloniod power #3
I don't have a manual for a 7 series, but typical Deere safeties that must be online for the crank circuit are brake and PTO. No spark would indicate that is likely what you are looking at. Many times the purple wire feeds through the PTO switch. Know the fuses are good and cycle the PTO switch a few times. It also may be wired to need imput from the MIR switch at the transaxle as well. I don't see an ECU either.
Thank you very much. I will try again today.
Got it the PTO switch was bad. Thanks all of you for your help!
Appreciate that!
Steel Rollup Door (A45336)
Steel Rollup Door...
2019 Chevrolet Colorado 4x4 Pickup Truck, VIN # 1GCGTBENXK1257105 (A44391)
2019 Chevrolet...
NEW Wolverine 3PT Hitch Receiver (A48289)
NEW Wolverine 3PT...
2016 Dodge Ram 2500 (A47307)
2016 Dodge Ram...
2012 Hyundai Sonata Hybrid Sedan (A46684)
2012 Hyundai...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A46683)
2012 Cottrell...
