John Deere X530 Hydraulic Lift Lever Replacement
   / John Deere X530 Hydraulic Lift Lever Replacement #1
Ledgemere Farm
Veteran Member
Limerick, Maine
A bunch
My lever snapped off, it seems to be a common issue, has anyone replaced theirs and how difficult was it? As in can you replace it from the top or must you get at it from underneath?
   / John Deere X530 Hydraulic Lift Lever Replacement #2
Did the plastic lever break of just pull off the steel shaft? On my X540 the plastic lever will pop off the steel shaft if you pull up on one of the corners. On mine I just pushed it back onto the steel shaft.
   / John Deere X530 Hydraulic Lift Lever Replacement #3
It can be a little tricky to replace. There are several YouTube videos showing the procedure.
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
(1) MAYTAG REFRIGERATOR (A51248)
(1) MAYTAG...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
