Joystick won't return to neutral
   / Joystick won't return to neutral #1
B7500
Platinum Member
Tupper Lake, NY
Kubota B7500 HSD
Joystick won\'t return to neutral
My Kubota right hand backhoe joystick won't return to neutral without manually doing so. I sprayed WD-40 but that don't help. Any ideas?
Thanks,
Terry
   / Joystick won't return to neutral #2
Re: Joystick won\'t return to neutral
Just a possibility, my iseki had a valve that would loosen the spring behind the valve that kept it centered. It was under the cap on the back of the valve that would not work right.
Fixed the problem. My dealer told me to keep spraying the pivot knuckle before it goes into the valve and work it back and forth. After a while it started to loosen up and now it freely returns to neutral.
My baby is just like new.
   / Joystick won't return to neutral #4
B7500,
Thanks for the "fix" to your sticking joy stick. My FEL joy
stick has been getting progressively worse lately and the
my forward/reverse control is starting to do the same. Now
if I can just REMEMBER to take the WD40 out the to the
property maybe I can get it fixed!!! /forums/images/graemlins/confused.gif
I forgot last weekend! /forums/images/graemlins/grin.gif
Thanks,
Da
Let me know if you fixed it.
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
UNUSED Bubble Aluminum Foil Reflective Insulation (A50860)
UNUSED Bubble...
2005 Ford Freestar SE Van (A48082)
2005 Ford Freestar...
2018 Nissan Versa SV Sedan (A48082)
2018 Nissan Versa...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
