Just bought 1 owner 1979 John Deere 1050 tractor
   / Just bought 1 owner 1979 John Deere 1050 tractor #1
mrowan
Willow Spring,NC
2014 LS R3039H
What's everybody's opinion on this tractor,only has 1100 hours? TRACTOR1.JPG
   / Just bought 1 owner 1979 John Deere 1050 tractor #2
That is very low hours. It looks good. I would get those hoses raised or protected because I know my luck.
   / Just bought 1 owner 1979 John Deere 1050 tractor #3
I'll second the hoses need raising. Don't drive it in the mud or you will be STUCK. BTDT Back when I worked for a JD dealer those series tractors as a rule had very few hours of use every year. They are good tractors but parts can get very high $$$$$$.
   / Just bought 1 owner 1979 John Deere 1050 tractor #4
I had one for a few years. I bought it with about 3200 hrs on it. It was a bargin. It looked pretty good, and only had a few issues. I replaced the head gasket, bought a battery, replaced two front tires, and split it to adjust the clutch. (plus some paint and decals for the bling factor) The pto would scrub when engaging. The pto scrubbing came back after a while, and I think it really needed the clutch replaced. I sold it about a year ago and replaced it with a 4720. Mine also had turf tires. The traction was somewhat limited. I used it mostly for mowing and box bladeing. I was a neat tractor. Simple and reliable. If mine had a front end loader, I would probably still have it.
   / Just bought 1 owner 1979 John Deere 1050 tractor #5
Looks nice enough. Depending on $ and how the test drive goes, it could be a bargain.
Here is places for info that might help.
tractordata.com
tractorhouse.com
Good luck
Thanks for the input,runs like a top,
picked it up for $3500.00
Only issue was engaging in high range once.
Thanks again.
   / Just bought 1 owner 1979 John Deere 1050 tractor #7
Hard to beat a John Deere and that sure isn't many hours, it would of been a good buy with a lot more hours.
Agree with TX Jim, those tires do not go with mud, we bought a MF like that in 86 and because of our hills and getting stuck we traded it in on a MFWD. On dry ground with loaded tires, it was a really handy tractor.
   / Just bought 1 owner 1979 John Deere 1050 tractor #9
Very good buy from what I can see. Back in the day , we had 3 of these 1050s in our rental fleet. Gave good service and were worked hard by our customers. Most parts will exchange with its non turbo brother 950.
Not to worry you, but the hour meter can be stopped from working by turning off the key while operating. [ engine is shut down by pushing throttle to off, past low idle position] You can learn alot in the rental business about people and how they treat rental machines.....Oh,be sure and run good oil, rated for turbo diesels. And allow tractor to cool down its beautiful little turbo before shutting down by idling for a few minutes after working hard. Good luck.
   / Just bought 1 owner 1979 John Deere 1050 tractor #10
We've had a 950 since '86. Since ours was always (until one month ago) parked outside in the Pacific North Wet, several problems developed because of that. The clutch sticks to the flywheel during storage unless we kept the pedal depressed with a set of vice grips. The drums easily become packed with mowing detritus, and shifting gears takes the touch. That said, I would buy another, it's a great and fun machine
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
John Deere 825i Gator (A50514)
John Deere 825i...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2014 GMC Sierra Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
