• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Just purchased my Summit tractor and flashers and turn signals do not work
   / Just purchased my Summit tractor and flashers and turn signals do not work #11
...most electrical parts are one click away from total failure, even when new on the shelf.
Most electronics, short of electrolytic and tantalum capacitors, are designed to 1 million hour mean-time to failure (MTTF). That's just over 114 years, which of course is a mean (average), which is where things like standard deviation (consistency) become important.
What you're usually seing is not "electrical part" failure, but usually failure of the mechanical components. It's always the electromechanical components that fail in any system, not the electronics.
Think of your 30 year old home stereo, and what broke? The electronics, or the tape deck? The electronics, or the CD transport mechanism? The electronics, or the belt on the turntable?
In your car, what bit of "electronics" always breaks first? Mechanical relays and mechanical blinkers, or mechanical window switches.
Electronics rarely fail, unless over-volted or struck by lightening. It's always the mechanical or electromechanical components that go, first.
   / Just purchased my Summit tractor and flashers and turn signals do not work #12
Im not sure its just the flasher unit. Usually turn and hazard flashers are 2 separate units. My tractor has 2 flasher units, so do all my trucks. I cant see 2 flashers controls failing at same time
   / Just purchased my Summit tractor and flashers and turn signals do not work #13
@Triple 5423, debug of these systems is pretty simple. What tools do you have available? Test light? Multimeter?
Generally speaking, you put the tractor in a state where the blinker should be working, and then chase the circuit from one end to the other. So, key in run position, blinker switched on, check at bulb socket with your test light. If no power, move up to the fuse panel and check voltage coming into the blinker relay. If good, try jumpering the blinker relay with a scrap of wire or paperclip. Does the blinker light? If no good, move upstream to the fuse, and check for voltage on both sides of that.
If you find voltage all along the way, and it's still not lighting, then it's time to chase your ground path. Run a ground wire from battery negative right to negative side of blinker bulb socket housing. If blinker starts working, move that incrementally upstream until you find the bad connection.
   / Just purchased my Summit tractor and flashers and turn signals do not work #14
Summit sells thru box stores that do not do service. Service is done through a separate group of companies. Check the website to see if one is closer.
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2004 Freightliner FL70 Trash Truck, VIN # 1FVABTCS64HM47795 (A54865)
2004 Freightliner...
2009 INTERNATIONAL PAYSTAR 5600I FLATTOP SLEEPER (A55745)
2009 INTERNATIONAL...
1999 Southwind Class A Motorhome (A55853)
1999 Southwind...
2012 Kia Sorento SUV (A55853)
2012 Kia Sorento...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
Ad bottom of page
