Backhoe JW-03 Backhoe Problems
   / JW-03 Backhoe Problems #1
cv63usafsfs
John Deere 790
Hey guys,
I was using my jw03 backhoe today when the boom lift function stopped working. It has been kind of slow in the past and now it has gotten to the point where the boom just sinks down instead of raising up. However after moving around all the other cylinders for a while, the boom will randomly raise back up and then stop working again. Anyone had this problem?
   / JW-03 Backhoe Problems #2
I had a LW-6. Same thing happened to me. Cup seals are blown in the boom cylinder. Is your hydraulic oil kinda dark? If so, the seals have disintegrated. The good news is that the cylinder overhaul kits have urethane (opaque white color) seals instead of rubber.
   / JW-03 Backhoe Problems #3
Hey guys,
If you put the boom in a position, does it stay there, or does it sink down by itself? IE, will the boom cylinder support the weight of the boom? If it stays in place, I am going to have to disagree with Bob, and say the seals are probably OK. All the other circuits take a fraction of the hydraulic pressure to move compared to the boom up command. The control valve does not have individual load check valves, so when you give a boom up command, the pressure in the main input gallery must be greater than the pressure created in the cylinder by the weight of the boom. Boom going down when you command up(if that is the only command being given) is a classic symptom of low pressure in the main valve gallery. There is a check valve at the valve inlet, under that large standard screw head on the left side of the valve when seated, directly above the pressure relief valve. This keeps fluid from flowing backward into the pump outlet. So if the fluid cannot go back to the pump, where can it go? All this points to a leaking pressure relief valve IMO.
You need to hook up a pressure gauge and see what pressure you are getting. If you search back thru this forum, for this type BH, I posted an article about a little adapter I cooked up using a metric to NPT adapter that screws down in place of that screw head cap above the check valve. Into this you can screw in a pressure gauge to easilly test the pressure that the relief valve is delivering to the system when you load up a circuit...
Thanks for the replies!
The boom does not sink down until the I give it the boom up command. I am kind of new to tractoring and even newer to this backhoe. It did not come with a manual so I am kind of flying blind as to what the different parts are. Anyone have a labeled picture or something that I could use to figure out what all the parts are and get my bearings straight?
   / JW-03 Backhoe Problems #5
You probably nailed it Ron. Pump or PRV issues. :thumbsup:
I forgot about the sinking boom, which mine did.
   / JW-03 Backhoe Problems #6
You might try removing the load checks and cleaning, or the piston seals in the cyl are bad.
Check the relief pressure for correct setting.
   / JW-03 Backhoe Problems #7
You might try removing the load checks and cleaning, or the piston seals in the cyl are are bad.
Simple valve, no load checks. It only has a single checkvalve at the valve block inlet... You pretty much only ever command boom up by itself on these hoe's. Boom up with any other command = boom going down and the other command happening at an accelerated rate fed by the fluid from the heavily loaded boom cylinder backfeeding the system and providing additional flow to the other lightly loaded circuit.
cv63usafsfs What type pump are you feeding this BH with from your JD tractor? what engine RPM are you running? I might have a diagram I can upload tonight, I will look when I get home.
   / JW-03 Backhoe Problems #8
cv63usafsfs
Send me a PM with your Email address and I can send you a PDF file of the User Manual which contains part breakdowns.
RonJ
   / JW-03 Backhoe Problems #9
cv63usafsfs
RonJ
Cool Ron, that was the one I was thinking I have at home, which I got from you:)
ERJ I sent you a PM. I don't know the specific type, just that its a PTO pump and not a power beyond from the JD. I usually run it around 10,000 - 12,000 RPM, slightly above idle. I ran into a marine hydraulics guy today at work and ran the question by him. He thought it might be a lack of pressure which is causing the pressure release valve of the cylinder to not function or a stuck release valve. Thats what I was kind of thinking and would explain why just that one function doesnt work but may randomly work when the fluid is cooler. What do you guys think?
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2008 Genie ManLift (A50322)
2008 Genie ManLift...
