Mowing JX60 clutch problem
   / JX60 clutch problem #1
4DD
ATHENS, TEXAS
CASE IH JX60
Hoping someone can help me ensure the clutch is the problem before I split this tractor.
I was mowing with my Case JX60 with 1200 hours. All was fine but noticed that the PTO shaft was turning slowly. I depressed the clutch just a little and the PTO sped up again. The jx has a 2 stage clutch so I looked at the PTO cable and noticed it had a lot of slack. Using the adjustment I took up the slack and fired up the tractor. I engaged the PTO and it ran great but when I let out on the clutch I didn't move! I put back some slack in the PTO cable and tried it again. Now the tractor clutch worked but the PTO shaft slip although not as much as before.
I need to know if this is symptomatic of the clutch starting to go out?
Thanks for any help or suggestion.
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
