K3B engine timing--Shims?
   / K3B engine timing--Shims? #1
Farmall
Anyone know how to time a k3b mitsubishi engine? Is it shimmed and where could I get the right shims? This is in a Massey Ferguson 1120 tractor. When I bought this tractor I was told it needed an injection pump. It barely ran pouring black smoke when it was loaded in my truck. Since, I have not been able to get it to run.Supposedly the engine had been gone through, but it all seems suspect to me. Where can I get parts reasonably priced? I may need a rebuilt injection pump, injectors and probably glo-plugs, maybe a gasket set. Thanks for any help.
   / K3B engine timing--Shims? #2
You are not likely to find Mitsu parts reasonably priced. You may well not find them at all in the aftermarket. Case sold some as CaseIH compacts before the NH buyout. Maybe something there will cross over. But they never gave parts away, either.
   / K3B engine timing--Shims? #3
The K3B uses shims. I can supply you with new & used Mitsubishi parts.
FRONTIER WR3212 LOT IDENTIFIER 54 (A53084)
FRONTIER WR3212...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2020 COLOMBO TM LOT IDENTIFIER 201 (A53084)
2020 COLOMBO TM...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2023 New Holland CR10.90 Combine - Engine Hours - Separator Hours (A53472)
2023 New Holland...
(1) UNUSED 5200# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 5200#...
