kawasaki fd620d
   / kawasaki fd620d #1
ceekur
Sperry
John Deere 445
recent re-ring and bearing ( was run out of oil) got lucky only the bearing was ruined..........After 4hrs of break in changed the oil and the filter looked as if no oil ever entered it ?? However oil was so clear unsure, did not cut into yet, will tomorrow. Is it possible for oil not to enter the filter yet oil circulates in the engine as it should ????? thanks Ken
   / kawasaki fd620d #2
I'd think a certain amount of oil would drain out of the filter if indeed oil had entered it. Not sure what is up.
   / kawasaki fd620d
I drained engine for quite some time before removing filter, so possibly it drained the filter ? and with the oil still so clear, possibly just didn't see it. I put filter upside down on clean shop towel only oil I saw for sure was around the rubber seal. Will remove the filter first on next change, thanks for the reply :)
   / kawasaki fd620d #4
A quick way to tell if oil is getting the the oil filter is to fill the engine with the proper amount of oil, leave the oil filter off and disable the ignition system by in plugging coils, or spark plug wires and crank the engine over. There should be a healthy amount of oil coming out were the filter screws on. Quick but messy way of telling if oil is flowing to the filter.
I would only crank it with the starter and not allow the engine to start for obvious reasons. Lol
   / kawasaki fd620d
Thanks for the reply, I will do that at next change :)....Need to do some reading, it has a check ball and spring, <is it used to keep oil from draining back into sump or a pressure relief ? thanks again :)
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
